ianmcpherson's avatar
ianmcpherson
ReadyNAS Duo v2 Indicator Lights
Hello All -
I have recently replaced the hard drives in my ReadyNAS Duo v2 with 2 Western Digital Red 4GB drives.  Initially I was able to transfer data to them but now the ReadyNAS just shows all four blue lights and is unresponsive after power up.  I have tried to reset it with and without the discs but get nothing.  Has it died?  Any other, less terminal ideas?
And, if I do need to replace it, will other NASes be able to read the data?
Thanks,
Ian.
