msrendorg
Mar 31, 2022Tutor
Readyshare - how to backup onto computer
I love using the USB on the router for files we share on several computers but would like to be able to automatically on a scheduled basis save those files on one of my computers so they get backed u...
- Apr 08, 2022
As DexterJB says, third party software might be a good solution.
You could investigate whatever you now use to backup those PCs. It may be possible to add ReadySHARE drives to the current backup regime.
In my case, I use SyncBack to backup files to and from ReadySHARE drives:
Backup Software that does everything you need, and much more
DexterJB
Apr 07, 2022NETGEAR Moderator
Hi, welcome to the community. You can check the link below for an overview of the supported features and functions of ReadySHARE.
https://kb.netgear.com/20391/ReadySHARE-USB-Storage-GUI-explained?article=20391
You may need third party software/solution for what you're looking to achieve.
Dexter
NETGEAR Team
