msrendorg
Mar 31, 2022Tutor
Readyshare - how to backup onto computer
I love using the USB on the router for files we share on several computers but would like to be able to automatically on a scheduled basis save those files on one of my computers so they get backed u...
- Apr 08, 2022
As DexterJB says, third party software might be a good solution.
You could investigate whatever you now use to backup those PCs. It may be possible to add ReadySHARE drives to the current backup regime.
In my case, I use SyncBack to backup files to and from ReadySHARE drives:
Backup Software that does everything you need, and much more
michaelkenward
Apr 08, 2022Guru - Experienced User
msrendorg
Apr 13, 2022Tutor
Thank you! Syncback works perfectly - even set up two "backups" on alternate days so I have a plan c.
- michaelkenwardApr 13, 2022Guru - Experienced User
Glad that works.
With it "batches" and "Fast Backups", Syncback is powerful but can be intimidating.
I am of the "can't have too many backups" school.
