forrestjf
Mar 20, 2021Aspirant
ReadyShare 3.1 installation doesn't work on MacOS 11.2 (Big Sur)
I just purchased a new Mac and the only thing that doesn't work on BigSur is the Netgear ReadyShare Printer software. It won't install correctly. I've tried turning off Firewalls, Malwarebytes, and...
antinode
Mar 20, 2021Guru
> [...] Is Netgear going to fix this? [...]
I wouldn't hold my breath:
https://community.netgear.com/t5/x/x/m-p/1492455
As you can tell from the date and the different-style pop-up box, the
problem pre-dates Big Sur.
Does your (unspecified) printer lack its own network capabilty?
forrestjf
Apr 05, 2021Aspirant
I've had to connect it through WiFi, but that only works with some apps, not all. If would be nice if all the features I paid for with the Nighthawk actually worked. I've lost the DNS based Parent Controls as Netgear's pushing a paid service. But I already have (had) as service that worked fine (open source and free). I don't mind them adding the option of an app/paid service, but removing any ability to use parts of the product I already paid for doesn't seem right.
- antinodeApr 06, 2021Guru
> I've had to connect it through WiFi, [...]
So, that's a "yes" to your (unspecified) printer having its own
network capabilty?> [...] but that only works with some apps, not all. [...]
Not enough meat on that bone to sustain a house-fly larva.
As usual, showing actual actions (commands) with their actual results
(error messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.I wouldn't expect a printer connection to depend on which app is
trying to use the printer. The app should deal with the OS, and the OS
should deal with the printer.> [...] If would be nice if all the features I paid for [...]
Nice for you, not so nice for Netgear, apparently.
