JohnRock's avatar
JohnRock
Follower
Jun 13, 2020
ReadySHARE backup problem
I just attached a WD easystore 8 Tb drive to the router to use as a backup drive. In installed ReadySHARE and set up a backup scheme using the defaults. After waiting overnight for the first full bac...
  • antinode's avatar
    Jun 13, 2020
    > [...] the ReadySHARE Vault dashboard reports Backup protection at 34%,
    > When I look at the backup files from the Restore tab, nearly all my
    > folders are there but most if not all have only some of the files backed
    > up.
       If the backup job was "34%" complete, then I would not be amazed if
    not all the files had been saved.
       I'd give it another day or two before declaring a disaster.
       These routers are not especially quick at this task.  Even with a
    more serious NAS system, an initial backup job can be pretty slow.  On
    the bright side, future incremental backup jobs should involve less
    work, hence less time.
    > Is there some setting or file attribute or other problem that is
    > causing the backup routine to miss the majority of my files?
       The user didn't let it finish?
