kmboardman1
Nov 25, 2021Aspirant
Readyshare backup
I have used Readyshare Vault to back up to my USB drive in the past, however I see that is no longer supported, I signed up with Readyshare Cloud and can not find where the backup function is. I down...
michaelkenward
Nov 26, 2021Guru - Experienced User
kmboardman1 wrote:
Can someone please direct me.
Not without some l knowing of what Netgear hardware you own.
Is this a router or an NAS of some sort?
What do you mean by "backup function"?
Where to find it in the browser graphical user interface?
If you want the client for your PC or mobile device, try visiting the support pages for your hardware.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
- kmboardman1Nov 26, 2021Aspirant
Router R8000
I have an old WD My Book drive attached to the routers USB.
What I am asking, with Vault there was a back up tab, I don't see anything relating to backing up with Ready Cloud. Its says the Netgear will no longer support vault, so I dont want to use it any more.
Support | NETGEARBeen there.
That page will also have any software, firmware and drivers for your device, if they exist.- michaelkenwardNov 26, 2021Guru - Experienced User
Is this what you read?
Support for Readyshare Vault ends April 15, 2021 | Answer | NETGEAR Support
ReadyCloud and Readyshare Vault are two different things.
Not sure what more anyone can say beyond suggesting that you look for an alternative backup system. There are plenty of them out there.
That is what is so frustrating, Netgear no longer supports Readyshare Vault but does not offer any suggestions for an alternative. Also, when you when I look at the Readyshare interface, there is a message concerning back up, but it takes you nowhere.
these other backup options, do they work with Netgear?
