Savier
Sep 10, 2021Tutor
readyShare does not allow me to connect to my HDD
Im not sure that I put the rounter name correctly, but if not, my router name is NighthawkAX8AX6000 WiFI Cable Modem Router, Model CAX80. So before readyShare allowed me to connect to my HDD with th...
Sep 10, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem Gateway products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "Nighthawk WiFi Routers" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
- SavierSep 10, 2021Tutor
Okay, thank you
