Yelpy
Nov 28, 2023Tutor
ReadySHARE Media Drive constantly disconnecting
Hi all, I just made this account so that I could post an issue and it's fix. I have the Nighthawk X4 AC2350 (R7500v2) and for a while now the media hard drive I have connected via USB using ReadySHAR...
Yelpy
Nov 28, 2023Tutor
Maybe then they should write on the box, in big ass letters. THIS WILL BREAK AFTER 3 YEARS!!! 🤦
Nov 28, 2023Guru - Experienced User
This model router was first released back in 2014. Well past 3 years.
- YelpyNov 28, 2023Tutor
The link you posted said 3 years, hence 3 years!
- FURRYe38Nov 28, 2023Guru - Experienced User
Initial FW says 2016:
https://kb.netgear.com/25492/R7500-Firmware-Version-1-0-0-46
Hence well past 3 years. But please contact NG support and let then know as this is well beyond forum support. Nothing can be done here for some thats EoL.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/Good Luck.
I don't know what point you're trying to make. Whether the product is 3 years or 10 years old the fact remains they broke it with a firmware update, didn't let the people who own the bloody thing know and just left it like that. The fix I posted will help those people. Your replies won't, they're not helpful in the slightest.
