Retired_Member
Oct 18, 2016Readyshare not working in AP mode
Hello, because i am using my r7500 as a ''second'' router i put it in AP mode. after i did readyshare stopt working !! is it not possible to use readyshare in AP mode ?? that whould be a major ...
- Retired_MemberNov 10, 2016
apparently after you put it in AP mode you need to ''restart'' the router before you can acces Readyshare.
after i powerd off my router and turned it back on everything worked just fine :smileyembarrassed:
feel so stupid right now....... such a simple ''fix''
thanks for all the help and quick responses tho !! :heart:
Retired_Member
Nov 08, 2016Hello,
sorry for the delay, but i had givvin up.
i will try it now again, i am accesing readyshare wired and wireless ( both not working )
when i get the router back out of AP everything works again.
i have the R7500 V1
Retired_Member
Nov 08, 2016Netgear genie doesnt see my HDD anymore aswell
- Retired_MemberNov 08, 2016
Is the ready share setup greyed out when using AP mode?
no it is not
My 2 cents
if this was setup in router mode and then changed to AP mode would the IP change be the problem?
