Retired_Member
Oct 18, 2016Readyshare not working in AP mode
Hello, because i am using my r7500 as a ''second'' router i put it in AP mode. after i did readyshare stopt working !! is it not possible to use readyshare in AP mode ?? that whould be a major ...
- Retired_MemberNov 10, 2016
apparently after you put it in AP mode you need to ''restart'' the router before you can acces Readyshare.
after i powerd off my router and turned it back on everything worked just fine :smileyembarrassed:
feel so stupid right now....... such a simple ''fix''
thanks for all the help and quick responses tho !! :heart:
ElaineM
Nov 10, 2016NETGEAR Employee Retired
But will it work through IP?
Mine works ok.
Retired_Member
Nov 10, 2016apparently after you put it in AP mode you need to ''restart'' the router before you can acces Readyshare.
- ElaineMNov 10, 2016NETGEAR Employee Retired
You're welcome!
Glad to hear that it's all working now.
Do not forget to mark the solution.
