radon85
Dec 14, 2019Guide
Readyshare not working Windows 10.
 I'm tired of waiting on the SMB1 fix.  Am I missing something or wouldn't it be easier if Netgear simply added support for an additional user (other than guest and admin)?
radon85
Jan 07, 2020Guide
IrvSp,
Yes, I understand the battles and the headwinds. And I appreciate all the effort put forth beforehand. I'm simply looking to take a different approach and hoping it might be fruitful. Organizations like low hanging fruit and I believe this may be an easy way to workaround the issue. For a small amount of effort they could eliminate a problem with their customer base. Whether it is pursued is dependent upon how big of an issue it is with current customers and the direction of the marketing roadmap. Thanks again for the input.
