HMTerrace's avatar
HMTerrace
ReadyShare on Nighthawk R8000 X6 - USB drive not recognized
Model: Nighthawk R8000 X6 AC3200 'Smart WIFI Router' Firmware Version: V1.0.4.68_10.1.75   For several weeks I have been attempting to get ReadyShare to work on two separate copies (identical conf...
  • EU_Won's avatar
    Apr 22, 2021
    Yes, this is a recurring theme - sadly.
    On MY R8000 X6 AC3200 [ firmware: V1.0.4.68_10.1.75 ], I needed to go to the 'Advanced' tab on the web management interface.  On the drop-down list of options at the left, near the bottom of the Advanced Setup section is an option labeled USB Settings.  There is only a single action item there:
            Enable any USB Device connected to the USB port       Yes   No
    If the 'No' choice is selected, NO USB device will be recognized, ever.
    Hope that helps.
