HMTerrace
Apr 15, 2021Aspirant
ReadyShare on Nighthawk R8000 X6 - USB drive not recognized
Model: Nighthawk R8000 X6 AC3200 'Smart WIFI Router' Firmware Version: V1.0.4.68_10.1.75 For several weeks I have been attempting to get ReadyShare to work on two separate copies (identical conf...
- Apr 22, 2021
Yes, this is a recurring theme - sadly.
On MY R8000 X6 AC3200 [ firmware: V1.0.4.68_10.1.75 ], I needed to go to the 'Advanced' tab on the web management interface. On the drop-down list of options at the left, near the bottom of the Advanced Setup section is an option labeled USB Settings. There is only a single action item there:
Enable any USB Device connected to the USB port Yes No
If the 'No' choice is selected, NO USB device will be recognized, ever.
Hope that helps.
EU_Won
Apr 22, 2021Initiate
Hope that helps.
HMTerrace
Apr 23, 2021Aspirant
WHOA! it WORKS
Thank you for the simple abut elusive solution.
