jedensuscg's avatar
Nov 30, 2016
READYSHARE options keeps giving blank pages, can't change add folders.
So i decided to plug in my WD My Password Ultra (1TB version) into my router to use it as a media drive.  All went well at first. I loaded up the drive in the USB settings, restarted the router and w...
  • JamesGL's avatar
    JamesGL
    May 14, 2017
    Hi jedensuscg,
    What is the file format of the drive? Can you try to reformat it and use NTFS.
