jedensuscg
Dec 01, 2016Tutor
READYSHARE options keeps giving blank pages, can't change add folders.
So i decided to plug in my WD My Password Ultra (1TB version) into my router to use it as a media drive. All went well at first. I loaded up the drive in the USB settings, restarted the router and w...
- May 15, 2017
Hi jedensuscg,
What is the file format of the drive? Can you try to reformat it and use NTFS.
jedensuscg
Dec 02, 2016Tutor
Hello,
Thanks for the reply. I did try a different USB flash drive (explained above as well) and same thing. Also tried Edge, ie 11 and chrome and two different computers, and both wireless and plugged into via cat5.
Haven't tried rolling back firmware yet.
JamesGL
Dec 19, 2016NETGEAR Employee Retired
Hi jedensuscg,
Try rolling back to previous firmware and see if the same problem.
JamesGL
Community Team
