jedensuscg
Nov 30, 2016Tutor
READYSHARE options keeps giving blank pages, can't change add folders.
So i decided to plug in my WD My Password Ultra (1TB version) into my router to use it as a media drive. All went well at first. I loaded up the drive in the USB settings, restarted the router and w...
- May 14, 2017
Hi jedensuscg,
What is the file format of the drive? Can you try to reformat it and use NTFS.
BKAmputee
Feb 10, 2017Aspirant
I am also now getting a blank page on Advanced/Readyshare/Advanced Settings on my X4S. Was working fine until I added a new path to a large music folder, naming the new network folder "Rick's Music"
Now when I click on Advanced/Readyshare/Advanced Settings it says "Please wait a moment..." and the wheel spins for a while, then blank page. I did find if you click some combination of Media Server, Basic Settings, Advanced Settings, sometimes you can get the Advanced Settings page to load. It is kind of random how to get the page to load. I think if you click Media Server then click Advanced Settings quickly before that page loads gets you in. Then, if I hit the + button to create a new network folder I get the blank screen again.
A text screen popped up at some point with a link www.routerlogin.net/USB_Folder_creat.htm, not sure what that is about. I did try both chrome and IE 11 browsers, on two different devices, both behave about the same way.
I can still access the disk from other devices using the existing share name \\readyshare\external_disk, The new network folder I tried to create does not show up at all on the network.
Any ideas what is going on here?
Any suggestions how to fix this?
Image of text window which pops up, of you click on the "i" a message says "your connection to this site is not secure"
JamesGL
Feb 12, 2017NETGEAR Employee Retired
Hi BKAmputee,
1. What is the firmware version of the router? Make sure it is on the latest one.
2. Try to reset it and manually reconfigure.
- JamesGLFeb 15, 2017NETGEAR Employee Retired
Hi BKAmputee,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- BKAmputeeFeb 15, 2017Aspirant
Router Firmware Version
V1.0.2.20I reset the router and configured. Then I duplicated the exact same steps as before to set up the network folder, and the same thing happened again.
I have ordered another network storage device because I cannot effecively use the X4S storage for some reason. Hopefully a new firmware will be released soon to fix the Readyshare issue.
Thanks
