WildAndes's avatar
WildAndes
READYSHARE options keeps giving blank pages, can't change add folders
READYSHARE options keeps giving blank pages, can't change add folders. I have the newest firmware version 1.0.2.32 on a Nighthawk(R) X4S R7800.  Other people had similar the same problem in the past ...
  • JamesGL's avatar
    JamesGL
    Aug 18, 2017
    Hi WildAndes,
    Have tried a different computer?
    If still the same with other computer, you can try o reset the router.
