DrJB
Dec 09, 2021Aspirant
ReadyShare Print is BROKEN after latest R7900P firmware update
I've had this router for a couple of years, and I've always used Readyshare as a print server for my entire family. It has broken before, but I could always repair it with a reinstall. Not so now. The latest firmward update has broken the feature--and I would guess Readyshare vault, as well--and it seems irreperable (delete and reinstall, reinstall printers, etc.). The USB Control utility has not been updated for the entire time I have owned the router (remains at v.1.36), and all of my drivers are current. Are others having the same problem, and is Netgear listening?? Has anyone found a solution?
Readyshare is a marketing term wrapping various features and applications.
DrJB wrote:
The latest firmward update has broken the feature ... and it seems irreperable (delete and reinstall, reinstall printers, etc.).
Consider to roll-back the firmware and compare.
DrJB wrote:
... --and I would guess Readyshare vault, as well-- ...
Readyshare Vault was a backup application based on a 3rd party backup application from almost two decades ago, and never pushed forward. It's EoL'ed -> Support for Readyshare Vault ends April 15, 2021 (and hard disabled by a "kill-switch" in the application). the access to the router or the ReadyNAS was done using Readyshare USB access, a simple shared folder access system.
It's a dead simple USB-over-IP implementation creating virtual USB ports. Certain updates (partially major changes) on the WIndows side can require a re-installation. Beyond of this, it's rock solid. It's accessing a dedicated service allowing to "remote" a local USB port on the router side - something broken by the recent updates and/or removed features. Only the gods of Netgear router firmware know.
- DrJBAspirant
Yes, it WAS rock solid until the latest firmware, though I had to reinstall in numerous times over the past couple of years. And I understand precisely what it is and how it functions. A firmware rollback seems unwise, since this one supposedly addressed major security issues, but thanks for the advice. Who knows, perhaps a backdoor opened by Readyshare Print IS one of the security issues. I'd love to get it to work again, though.
What problems do you have?
From reports here, it doesn't seem to be a persistent issue with the R7900P. Other stiff, yes, but not ReadyPRINT.
That's by design. One of various "Cloud" services that Netgear has withdrawn. Free parental controls is another one.
This is usually flagged up on the release notes for new firmware.
Support for Readyshare Vault ends April 15, 2021 | Answer | NETGEAR Support
- DrJBAspirantPrinters connected to the Nighthawk USB no longer appear in the ReadyShare Print USB control center. In the past, I could fix similar problems with a control center uninstall and reinstall, but not now. The cause is definitely the new R7900P firmware released last week, because nothing else is changed, and it worked just prior to the update. In fact, I cannot gain access to the usb via any other means, either. No parental controls and minimal security on the router. I think this will show up in other posts soon, as this firmware update takes some effort to install (web based auto install does not work). I would guess that another firmware update might be necessary to restore this functionality.
