_JR
Nov 21, 2021Aspirant
ReadySHARE Printer Utility, download, etc.
NETGEAR Nighthawk X4S AC2600 Smart WiFi Router Model RC8700 Page 135 of my manual states to download the ReadySHARE Printer Utility I need to go to NETGEAR.com/readyshare Pressing that link r...
michaelkenward
Nov 22, 2021Guru - Experienced User
Not sure that I can understand where things are going wrong at your end.
I can find no reference to a RC8700 in the Netgear system. Perhaps you mean R7800.
Is that what you have?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software and firmware for your device.
The ReadySHARE Printer Utility Version 1.36 (Windows) is there.
Nighthawk X4S R7800 | AC2600 Smart WiFi Router | NETGEAR Support
That should be enough to get you going.
