_JR
Nov 21, 2021Aspirant
ReadySHARE Printer Utility, download, etc.
NETGEAR Nighthawk X4S AC2600 Smart WiFi Router Model RC8700 Page 135 of my manual states to download the ReadySHARE Printer Utility I need to go to NETGEAR.com/readyshare Pressing that link r...
th22
Dec 17, 2021Initiate
_JR
Dec 31, 2021Aspirant
I'm back...
Downloaded ReadySharePrinter_setup_v1.36.exe and installed it.
Now I get an app window with little more than question marks (see Ntgear Shared Printer Screenshot.jpg Photo link)
Did I do something wrong?
- _JRDec 31, 2021Aspirant
The Photo
Netgear Shared Printer Screenshot.jpg is not the screenshot I made. I'll try again.
- michaelkenwardJan 01, 2022Guru - Experienced User
_JR wrote:Did I do something wrong?
Probaby not.
Do you have something connected to the USB port on your router?
I still have no idea what Netgear device you are trying to set up. Probably R7800, but that just a guess based on "X4S AC2600", which tells us about the wifi technology rather than the model number.
Here is what I see:
USB Control Center
Try clicking the bit where "Tools" should be. Here it has "Language" options. The top one is "English".
- _JRJan 01, 2022Aspirant
Download ReadySharePrinter_setup_v1.36.zip
Install ReadySharePrinter_setup_v1.36.exe (and stipulate language = English) on computer hard wired by USB cable to NETGEAR R7800 router USB1. .
Screen shot (see attached) showing: Installation obvious (under Recently added [Win10])
On far tight NETGEAR USB Control Center window with [Connect], [Disconnect], [Network Scanner] buttons all greyed out.
Still not able to print:
Samsung ML-2850 Series (“USB002 Offline: 10 documents waiting”)
Unplug USB from NETGEAR USB1 and plug into USB2 and try again.
Samsung ML-2850 Series (“USB002 Offline: 11 documents waiting”)
Q: Why is window all greyed out?
Q: Why can’t I get the printer to come online?
- michaelkenwardJan 02, 2022Guru - Experienced User
What is "computer hard wired by USB cable".
The idea of ReadySHARE Printer is that you share the printer attached to the router by USB.
Is that what you did?
It has nothing to do with a USB connection between the computer and the printer.
Have you installed the printer and its drivers in all of the PCs on the network?
You might get to the solution quicker if you answered questions.
