swebs's avatar
swebs
ReadyShare seems to suck
Is anyone else actually using ReadyShare and getting it to work?   I recently added a HD to my Nighthawk X6 (R8000/AC3200) and enabled the readyshare. Both my computers see it and I started backups...
  • michaelkenward's avatar
    Mar 10, 2017
    swebs wrote:
    Sorry, I thought I was clear. It's the readyshare software that netgear provides.
    You can use any backup software on a Readyshare drive.
    I wouldn't trust Netgear's software to match the performance of a specialist package.
    SyncBackPro does a good job.
