swebs
Mar 08, 2017Aspirant
ReadyShare seems to suck
Is anyone else actually using ReadyShare and getting it to work? I recently added a HD to my Nighthawk X6 (R8000/AC3200) and enabled the readyshare. Both my computers see it and I started backups...
- Mar 10, 2017
swebs wrote:
Sorry, I thought I was clear. It's the readyshare software that netgear provides.You can use any backup software on a Readyshare drive.
I wouldn't trust Netgear's software to match the performance of a specialist package.
SyncBackPro does a good job.
swebs
Mar 10, 2017Aspirant
Sorry, I thought I was clear. It's the readyshare software that netgear provides. Readyshare on the router and the readyshare clients on Windows 7 and Windows 10.
- michaelkenwardMar 10, 2017Guru - Experienced User
- swebsMar 10, 2017Aspirant
Checked out the free version of SyncBack "SyncBackFree".... Its fricken AWESOME. Exactly what I needed.
- michaelkenwardMar 11, 2017Guru - Experienced User
Does it work OK with Readyshare for you?
