jackvans
Jan 18, 2017Aspirant
ReadySHARE USB Printer
Where do I find the ReadySHARE USB Printer for macOS Sierra (Mac OS X 10.12)? I was here: http://downloadcenter.netgear.com/?cid=wmt_netgear_organic#searchResults, but that vesion doesn' work. Tha...
ElaineM
Jan 19, 2017NETGEAR Employee Retired
Welcome to the community, jackvans
Contact support and tell them that you need the compatible USB Control Center Utility for your Mac computer.
- jackvansJan 21, 2017Aspirant
Thank you for your reply. Isn't that weird. Why should you a ask (beg) for software. It should be available on their download site. On the download site is only old OS X stuff.
- Sui_GenerisFeb 21, 2017Aspirant
Hi there,
I can't seem to contact support without having to pay to support...
I would like to download the beta version of the USB printer Controller.
- frkirkFeb 21, 2017Aspirant
I too need the compatible USB Control Center Utility for your Mac computer with macOS Sierra. It won't even allow me to uninstall it.
- aalexandrebetaFeb 21, 2017Master
Can't Netgear make an option allowing users to configure the feature thru the OS and not thru an useless program!!!!!!
