HHHY
May 03, 2021Aspirant
ReadyShare USB storage - unable to use.
Just these holiday I started to explore the ReadyShare facility on my router. So far I have been able to see a USB stick (resp 32 and 8 GB) on the ReadySHARE tab in my RouterLogin page. It recogniz...
- May 12, 2021
HHHY wrote:
For some reason my ReadySHARE won't work.
OK. So we can forget about ReadySHARE VAULT.That is something completely different.
HHHY wrote:
When installing the ReadySHARE software on the laptop it does not see the USB drive.
Yes, but what ReadySHARE software?
You do not need any software to use ReadySHARE. You set it up in the R7800's GUI (browser interface), USB drives then becomes visible in Windows as a Network location called \\READYSHARE.
It should appear in Windows Explorer. Then you can use whatever software you like to address it.
It may be that Windows or something else is protecting you.
It works here just fine. So nothing has changed on the R7800 on that front.
This may be useful:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
michaelkenward
May 12, 2021Guru - Experienced User
This may be useful:
HHHY
May 15, 2021Aspirant
That involved sacrificing security and increasing vulnerability to Wannacry if I understand correctly... Naaah..
