weijenc
Sep 04, 2021Follower
Readyshare Vault Download (broken?)
It seems that the link to download the ReadyShare Vault is broken (https://www.netgear.com/support/product/ReadySHARE_Vault.aspx). Is there a mirror site to get this software? I fear that I may not...
leoandrisones
Sep 05, 2021Aspirant
weijenc wrote:It seems that the link to download the ReadyShare Vault is broken (https://www.netgear.com/support/product/ReadySHARE_Vault.aspx ). Is there a mirror site to get this software?
I fear that I may not be able to recover files backuped (and encrypted) by using ReadyShare Vault....:(
Is working fine on my end . Double check you connection and also check if there is firewall sometime block certains website.
michaelkenward
Sep 05, 2021Guru - Experienced User
Not here. Times out.
This might explain things:
Support for Readyshare Vault ends April 15, 2021 | Answer | NETGEAR Support
How to setup ReadySHARE Vault (Free Backup Software)? | Answer | NETGEAR Support
