jwild's avatar
jwild
Follower
Feb 07, 2021
Readyshare Vault Software Not Downloading
I keep going to https://www.netgear.com/support/product/ReadySHARE_Vault.aspx#ReadySHARE%20Vault%20PC%20Utility to download the ReadyShare Vault software to my new laptop, and it keeps timing out with the error updates1.netgear.com took too long to respond. I tested my wifi connection, and I'm getting 200Mbps, so the problem looks to be on the server side. Anybody else having this problem? Is there another way to get this software?
1 Reply
  • > [...] Anybody else having this problem? [...]
       Yes.
    > [...] Is there another way to get this software?
       Changing "https://" to "http://" worked for me.  (I'd call that a
    server problem.)
