turn00
May 08, 2021Aspirant
ReadyShare Vault Software will not download.
Readyshare vault will not download. It times out every time and says network error. Is there anywhere else I can get a copy of this software? Thanks
michaelkenward
May 09, 2021Guru - Experienced User
And your Netgear device is? Are you trying to download from its support pages?
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Then there is here:
Is that where you had a problem?
