slowmotionq's avatar
slowmotionq
Follower
Nov 05, 2020
ReadyShare will not stream. States, "Downloading not supported at this time." Please advise.
I just purchased a NightHawk AX5200.  I previously had a cable-modem/router combo.  The ReadyShare on the combo unit worked fine; however, on the AX5200 the ReadyShare will not stream the movies I have hooked up to the USB port.  I can see all of the files but when I select on I get a reading, "Downloading not supported at this time."  I've reset the router but still no luck.  Please advise.
1 Reply
  • plemans's avatar
    Not sure what modem/router combo device you had before but it potentially had a dlna server built into it. Many of netgears routers had that for a while. i haven't seen dlna built into any of the newer AX routers. And support was even pulled from some of the older AC routers to add in netgear armor.
