W0lfd
Sep 14, 2016Initiate
ReadySHARE Windows 10 + KB3189866
Windows 10 cumulative update KB3189866 breaks readyshare. :smileysurprised:
Uninstall it if you can't access your readyshare folder.
- Sep 25, 2016
Problem solved.
The solution below absolutely worked for me!
The one thing to say is that when you create the Windows Credential - you must enter a user name and password, and...
1. I had to configure readyshare itself to allow read and write access to a username - i selected admin.
2. The windows credential required the router username "admin" and the password for admin. I tried my windows username and password, and i was able to connect to map the drive, but not open the contents of it. With admin and the password, i was able to get it to work!
>Found a solution:
>go into user account in control panel
>if you're in windows 10 select manage your credentials this will open 2 options
>web credentials and windows credentials
>head to windows credentials and add a new windows credential
>enter the location of the drive \\readyshare on the first line
>your windows user name in the second line
>your windows password in the third line
>and you're done, you should see the drive under network and be able to access it as before
>good luck
pblagay
Sep 15, 2016Star
I can confirm this. I had the same problem on R6250 router. Uninstalled the latest update and it's now working again.
Message I would receive was:
A specified logon session does not exist. It may have already been terminated.
I have tried recreating the drives, resetting the router, the PC, checked my credentials on WIndows. Storing network credentials is disabled
ElaineM
Sep 16, 2016NETGEAR Employee Retired
Can you guys share a screenshot of the error you're getting?
- W0lfdSep 16, 2016Initiate
- pblagaySep 16, 2016Star
Not currently near my computer but the exact message I was seeing in the dialog:
\\RouterShare is not accessible. You might not have permisssion to use this network resource. Contact the administrator of this server to find out it you access permissions.
