W0lfd
Sep 14, 2016Initiate
ReadySHARE Windows 10 + KB3189866
Windows 10 cumulative update KB3189866 breaks readyshare. :smileysurprised:
Uninstall it if you can't access your readyshare folder.
- Sep 25, 2016
Problem solved.
The solution below absolutely worked for me!
The one thing to say is that when you create the Windows Credential - you must enter a user name and password, and...
1. I had to configure readyshare itself to allow read and write access to a username - i selected admin.
2. The windows credential required the router username "admin" and the password for admin. I tried my windows username and password, and i was able to connect to map the drive, but not open the contents of it. With admin and the password, i was able to get it to work!
>Found a solution:
>go into user account in control panel
>if you're in windows 10 select manage your credentials this will open 2 options
>web credentials and windows credentials
>head to windows credentials and add a new windows credential
>enter the location of the drive \\readyshare on the first line
>your windows user name in the second line
>your windows password in the third line
>and you're done, you should see the drive under network and be able to access it as before
>good luck
MrEugeneKrabs
Sep 18, 2016Tutor
Same here. R7000, a WD Elements and a WD My Password drive which can not be accessed from both a laptop with Windows 10 and a desktop with Windows 10. Started about yesterday or the day before that. Got the Windows update about 9/15. Upgraded the firmware of the R7000 but with no positive result. I can access both devices with my iPhone, iPad and AppleTV 4.
In the proces of recreating a connection on a Windows device I created a second link to one of the drives. This extra link was visible in the Apple devices but failed to work.
