W0lfd
Sep 14, 2016Initiate
ReadySHARE Windows 10 + KB3189866
Windows 10 cumulative update KB3189866 breaks readyshare. :smileysurprised:
Uninstall it if you can't access your readyshare folder.
- Sep 25, 2016
Problem solved.
The solution below absolutely worked for me!
The one thing to say is that when you create the Windows Credential - you must enter a user name and password, and...
1. I had to configure readyshare itself to allow read and write access to a username - i selected admin.
2. The windows credential required the router username "admin" and the password for admin. I tried my windows username and password, and i was able to connect to map the drive, but not open the contents of it. With admin and the password, i was able to get it to work!
>Found a solution:
>go into user account in control panel
>if you're in windows 10 select manage your credentials this will open 2 options
>web credentials and windows credentials
>head to windows credentials and add a new windows credential
>enter the location of the drive \\readyshare on the first line
>your windows user name in the second line
>your windows password in the third line
>and you're done, you should see the drive under network and be able to access it as before
>good luck
Hooch80
Sep 18, 2016Tutor
I have the exact same problem.
1. \\readyshare DOES NOT WORK - it results in "A specified logon session does not exist. It may already have been terminated."
2. HTTP access works
3. FTP access works
4. Creating a network share from the HTTP web site DOES NOT WORK
Any answers yet?
Hooch80
Sep 25, 2016Tutor
Problem solved.
>Found a solution:
>good luck
- MattMJFSep 30, 2016Aspirant
Hooch80,
I did this and it worked for me! Thank You for researching this and publishing the solution.
I just had the motherboard replaced on my Lenovo desktop computer and afterwards a plethora of Windows updates installed. I suspect my old credentials where lost or whatever.
I can now map the drive and access \\R7000\USBStorage
Great Job!
- LinotypeOct 01, 2016Tutor
Thank you Hoosh80. You solved a problem that has been a pain in my neck for over a week.
- MardnSNov 07, 2016Aspirant
Any fixture for Windows 8.1? None of the above worked for me.
- knightEknightNov 25, 2016Initiate
I found a different (but probably related) solution based on previous comments.
I logged in to my Windows 10 laptop as an administrator.
Opened a command prompt and issued the following command:
net use U: \\readyshare\USB_Storage /user:%username% /SAVECRED
After running this command one time I had no problem re-mounting the drive after a reboot with just this:
Then I right-clicked on Computer / Map Network Drive, selected U: and \\readyshare\USB_Storage, checked "reconnect at sign-in" and checked "Connect using different credentials". I specified my current username and password (just as I did in my original net use command above), and after this I could reboot the PC and the drive would be there. However, I'm pretty sure I would have to repeat these steps for every user I wanted to have access to it.
kEk
