W0lfd's avatar
W0lfd
Initiate
Sep 14, 2016
ReadySHARE Windows 10 + KB3189866
Windows 10 cumulative update KB3189866 breaks readyshare. :smileysurprised: Uninstall it if you can't access your readyshare folder.
  • Hooch80's avatar
    Hooch80
    Sep 25, 2016
    Problem solved.
    The solution below absolutely worked for me!
    The one thing to say is that when you create the Windows Credential - you must enter a user name and password, and...
    1. I had to configure readyshare itself to allow read and write access to a username - i selected admin.
    2. The windows credential required the router username "admin" and the password for admin. I tried my windows username and password, and i was able to connect to map the drive, but not open the contents of it. With admin and the password, i was able to get it to work!
     >Found a solution:
    >go into user account in control panel
    >if you're in windows 10 select manage your credentials this will open 2 options
    >web credentials and windows credentials
    >head to windows credentials and add a new windows credential
    >enter the location of the drive \\readyshare on the first line
    >your windows user name in the second line
    >your windows password in the third line
    >and you're done, you should see the drive under network and be able to access it as before
    >good luck
