Robert_Giuffre
Apr 27, 2020Follower
ReadyShare/NTFS 2GB file size limit?
I have a 500GB external hard drive formatted as NTFS attached to USB 3(1) on my router. I cannot copy a file larger than 2GB from a local PC to the ReadyShare drive. It says that there is not enoug...
- Apr 27, 2020
I think this is a SAMBA limitation. NG still uses the horribly outdated SMBv1 protocol
Brassai
Apr 29, 2020Tutor
Everything seems to be working great with his. File transfers are quick, all the stock Netgear options, apps, etc work as well. I will stick with Voxel unless Netgear decides to fix this issue with their own firmware.
microchip8
Apr 29, 2020Master
Brassai wrote:Everything seems to be working great with his. File transfers are quick, all the stock Netgear options, apps, etc work as well. I will stick with Voxel unless Netgear decides to fix this issue with their own firmware.
if you want more options (VPN, Adblocking, QoS, etc) install the kamoj addon. You can get it from https://www.snbforums.com/threads/kamoj-add-on-v5-for-netgear-r7800-x4s-and-r9000-x10.60590/
