Misterswede
Jan 27, 2022Guide
Reboot and DUMA OS not loaded on XR700
I had a power loss and restart of XR700 will not find my wifi, The LED 2.4 wont light up. And after 3 restarts nothing. Internet works.. If i use gatewaye via computer i get logn but after password...
Jan 27, 2022Guru - Experienced User
Try a full factory reset on the router and setup from scratch. Press the reset button for 10 seconds then release.
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Thank you.
