JBof4
Oct 11, 2021Aspirant
Reboot disaster Nighthawk
On Mac I’m in routerlogin.net I clicked update firmware, seemed fine until it kept asking me to sign in when I’m already signed in. Now in advanced “router information” it says “reboot” I click it tel...
michaelkenward
Oct 12, 2021Guru - Experienced User
Sign into what?
Are you wired to the router or on wifi?
What modem/gateway, if any, sits in front of your router?
How did you start the update? Using the browser graphical user interface (GUI)?
If you can regain control of the thing, a manual update is more controllable at your end. It can also pick up updates that yet to reach the update server.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
