bigmel97
Apr 20, 2022Tutor
Rebooting almost every day
I feel like I have to reboot this router almost every day. I don't know why. I changed out the cable from my ISP to the router, I've power cycled various times, but I'm still getting the same issue. ...
Apr 20, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. Do you have IPv6 enabled?
3. has a factory reset (not reboot) been tried?
4. Are you using smart connect?
bigmel97
May 01, 2022Tutor
I'm having the same issue. I've done all of that. I made sure that the devices are not on smart connect but I'm still seeing myself rebooting my router almost every day.
