sheaandmax
Jul 14, 2021Aspirant
Received an email for important firmware update for my MR and MS 60
When I logged in as admin on Nighthawk it said no updates available and online on the routerlogin page it stated that as well. But when I look at my firmware ware version and the one on the website,...
Jul 14, 2021Guru - Experienced User
What actual version are you on?
Sometimes the automatic update server gets updated at a later time than the manual one.
You always have the option of manually updating the firmware if you'd like to be current.
Or you can wait for the automatic server to update.
sheaandmax
I have version 1.0.6.102, When I went to the netgear IP address site, it also stated I was up to date and that is the only other way I know how to update the software.
- plemansJul 14, 2021Guru - Experienced User
You can manually update if you want to be current.
- sheaandmaxJul 14, 2021Aspirant
Thak you so much, I will certainly try that as I always like to stay updated and be on top of it!
After I manually set up my mr60 router, how do I manually set up the ms60 mesh satellites?
- plemansJul 15, 2021Guru - Experienced User
here's where you can get the satellite firmware.
https://www.netgear.com/support/product/ms60.aspx
there is a manual on bothsupport sites that goes over updating and installing
