sheaandmax
Jul 14, 2021Aspirant
Received an email for important firmware update for my MR and MS 60
When I logged in as admin on Nighthawk it said no updates available and online on the routerlogin page it stated that as well. But when I look at my firmware ware version and the one on the website,...
sheaandmax
I have version 1.0.6.102, When I went to the netgear IP address site, it also stated I was up to date and that is the only other way I know how to update the software.
Jul 14, 2021Guru - Experienced User
You can manually update if you want to be current.
- sheaandmaxJul 14, 2021Aspirant
Thak you so much, I will certainly try that as I always like to stay updated and be on top of it!
After I manually set up my mr60 router, how do I manually set up the ms60 mesh satellites?
- plemansJul 15, 2021Guru - Experienced User
here's where you can get the satellite firmware.
https://www.netgear.com/support/product/ms60.aspx
there is a manual on bothsupport sites that goes over updating and installing
