Retired_Member
Jul 10, 2016Recent firmware for R8500 results in permanent auto channel on 2.4 GHz
After updating to the last couple of firmware updates, e.g 1.0.2.64, 2.4 GHz band doesn't accept the channel selection like 1, 6, or 11. Instead, a wifi scan will show it transmitting something rando...
- Retired_MemberAug 08, 2016
Discovered a work around recently I wanted to mention. Turning off 20/40 MHz coexistence in the advanced wireless settings while running the 2.4 GHz band in 433 mbps mode will allow the router to broadcast the appropriate selected channel.
Retired_Member
Jul 10, 2016for what it is worth, I dial the 2.4 GHz radio back to 433 mbps setting to avoid the 40 MHz bandwith
Mikey94025
Jul 10, 2016Hero
Sorry, then I don't know what might be causing your 2.4Ghz channel issues. I didn't do exactly what you described (30-30-30) because I restored from my previous backup after the 2nd reset. In case it helps, I have these defaults changed for wireless settings:
- Wireless 1 = 2.4Ghz = channel 11, Up to 1000Mbps, WPA2-PSK [AES]
- Wireless 2 = 5Ghz-1 = channel 44, Up to 2165 Mbps, WPA2-PSK [AES]
- Wireless 3 = 5Ghz-2 = channel 153, Up to 2165 Mbps, WPA2-PSK [AES]
- Guest Network = unchecked Enable Guest Network for all 3 wireless radios (don't use my R8500 for guest network)
- Advanced Wireless Settings
- checked Enable 20/40Mhz Coexistence for 2.4Ghz
- unchecked Enable Wireless Router Radio for Wireless 5Ghz-1 (don't use this 5Ghz wireless radio)
- Implicit Beamforming is checked
- Airtime Fairness is checked
- Retired_MemberJul 10, 2016
Thanks for the input. Later tonight I'll try the reset before and after upgrading the firmware to see if it helps.
Believe I narrowed it down to what triggers the phenomena.
After doing two resets before and after a firmware update I changed each setting for 2.4 GHz one at a time.
Changed the channel to 6. No problem. Radio reports channel 6.
Changed the SSID and password. No problem.
Change mode from 1000 mbps to 433 mbps. Problem. Radio reports channels such as 4 or 7 instead of 6 in the settings.
Change mode from 433 mbps to 1000 mbps. No problem. Channel 6 reported correctly.
- Mikey94025Jul 10, 2016Hero
@kintpuash wrote:Believe I narrowed it down to what triggers the phenomena.
Good find!
- ElaineMJul 11, 2016NETGEAR Employee Retired
Retired_Member Do you have the NETGEAR Genie installed? Will it show different channel?
