Retired_Member
Jul 10, 2016Recent firmware for R8500 results in permanent auto channel on 2.4 GHz
After updating to the last couple of firmware updates, e.g 1.0.2.64, 2.4 GHz band doesn't accept the channel selection like 1, 6, or 11. Instead, a wifi scan will show it transmitting something rando...
- Retired_MemberAug 08, 2016
Discovered a work around recently I wanted to mention. Turning off 20/40 MHz coexistence in the advanced wireless settings while running the 2.4 GHz band in 433 mbps mode will allow the router to broadcast the appropriate selected channel.
Retired_Member
Jul 15, 2016
Another user on smallnetbuilder mentioning the same issue last month.
Retired_Member
Aug 08, 2016Discovered a work around recently I wanted to mention. Turning off 20/40 MHz coexistence in the advanced wireless settings while running the 2.4 GHz band in 433 mbps mode will allow the router to broadcast the appropriate selected channel.
- ElaineMAug 25, 2016NETGEAR Employee Retired
Retired_Member Thank you for that update.
