phoenix13
Aug 12, 2017Tutor
Recent Firmware updates on R8000 and R7000 break SonicWall SSL VPN Connectivity
I have spent nearly 40 hours investigating connectivity issues with SonicWall SSL VPN using the Dell SonicWall NetExtender client and the Windows 10 SonicWall Mobile app, which resulted in the root c...
- Jan 05, 2018
jlmartinjr, I did manage to get somewhere on this, I worked with Netgear to provide debug details that they used to develop a fix, which I successfully tested in a debug firmware build, but I'm not sure when this will be included in the mainstream firmware release.
I did find that I could reliably revert to R8000 firmware version 1.0.1.16 and was then able to connect to the SonicWall SSL VPN's, I would suggest that you try this in the short-term until the latest firmware resolves the issue.
phoenix13
Aug 13, 2017Tutor
Additional Information:
Both of the Palo Alto and London SonicWall Firewall/SSL VPN's being affected by this issue are running SonicOS Enhanced 6.2.6.1-25n
jlmartinjr
Jan 04, 2018Aspirant
did you ever get anywhere with this, I have updated to the latest firmware and I am having no luck.
Mine is a x6 R8000
- phoenix13Jan 05, 2018Tutor
