Jsuchii
Oct 02, 2021Aspirant
Recommendations to setup PC for 60Ghz wifi connection.
Hello! I own a typical windows gaming desktop that comes with the usual pre-installed 5Ghz/2.4Ghz wifi card and would like to install a wifi card that supports 60Ghz wifi for gaming/streaming with...
Oct 02, 2021Guru - Experienced User
Not worth the price in my opinion. the $ would be better put to a decent AC/AX card.
Jsuchii
Oh ok! It seems I should go for an AX router along with the wifi card instead. Do you have any recommendations for great ax wifi cards for gaming/streaming? Thank you in advance!
