Monty81
May 16, 2021Follower
Reconnecting Netgear ex3110 to wifi
I have a Netgear EX3110 which I use to connect a Fetch box in my bedroom to the internet. It was working fine until I had to get a new router. Now I cannot get it to connect and I have forgotten wh...
michaelkenward
May 17, 2021Guru - Experienced User
Monty81 wrote:
It was working fine until I had to get a new router. Now I cannot get it to connect and I have forgotten what to do.
Factory reset the EX3110 and set it up from scratch. You need to get it to forget the link with the previous router.
Visit the support pages:
Support | NETGEAR
Begin with the Quick Start/Installation Guide.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
