Ashi123
Nov 26, 2023Follower
Recovering admin password
Hi there I want to know how to recover not reset recover and the only videos online show how to reset
Nov 26, 2023Guru - Experienced User
If this method doesn't work, then you'd need to factory reset.
microchip8
Nov 26, 2023Master
Password recovery on NG routers has been broken for a very long time. It mostly sends you in a loop. The only way to reset a pwd is to factory reset. Make sure you have a config backup first for easy setup afterwards.
