mlfitch
Jul 10, 2024Follower
red internet light
I have a Nighthawk AX6 model # . The internet light which is the second one down is red. what does that mean and what do I have to do to fix it?
Jul 10, 2024Guru - Experienced User
Check out the user manual to see what the LED colors mean.
Try a power OFF of the ISP Modem and router for 1 minute then back ON.
Is this the R8000 model router?
