bhre
Jul 28, 2021Aspirant
Red LED Light
I have setup this router for my wifi network. All of the applicable LED lights are on that correspond with the various connections. The lights are white except for the light corresponding with the ...
antinode
Jul 28, 2021Guru
> [...] the light corresponding with the ethernet connection which is
> red. [...]
"the ethernet connection" to _what_? An Ethernet cable has two ends.
Follow it to the other end?
> [...] My question is why is the ethernet light red and not white?
If your "red" is what Netgear calls "amber", then you might try this
radical concept (which works for some people):
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for the LED descriptions. Further reading might not hurt, either.
