Capellam44
May 19, 2024Aspirant
Red WiFi light after resetting
Yesterday we had to do a factory reset on the router because the password that you wrote down wasn’t working. When the router came back online, we have a red light for Wi-Fi. I can access the admin se...
michaelkenward
May 19, 2024Guru - Experienced User
What router is this?
What do the other LEDs show? Power LED? Internet LED?
Why did you have to do a factory reset?
- Capellam44May 19, 2024AspirantSorry, I filled in all the text blocks and apparently it doesn’t show on the post itself. It’s a Netgear nighthawk R 7000 router. The red Wi-Fi light is the one that appears. All the rest are blue. Blue means that they function normally and red means that there is an issue. We had to do a factory reset because we needed to get into the admin section through the Internet. And the username and password that was written down did not work. I was told the only thing I could do to reset the password was to do a factory reset. I know we did this once before in the past and it was not this difficult. When I plug the Computer into the ISP cable and bypass the router altogether I have an Internet connection. So there is something with the router or the settings that I am missing.
- KitsapMay 19, 2024Master
Capellam44 wrote:
Sorry, I filled in all the text blocks and apparently it doesn’t show on the post itself. It’s a Netgear nighthawk R 7000 router. The red Wi-Fi light is the one that appears. All the rest are blue. Blue means that they function normally and red means that there is an issue. We had to do a factory reset because we needed to get into the admin section through the Internet. And the username and password that was written down did not work. I was told the only thing I could do to reset the password was to do a factory reset. I know we did this once before in the past and it was not this difficult. When I plug the Computer into the ISP cable and bypass the router altogether I have an Internet connection. So there is something with the router or the settings that I am missing.The second LED in from the right side (Wi-Fi), is a combination indicator/switch. With the router powered on and booted up, press and hold the LED indicator/switch for a few seconds and then release. You might have to do this a couple of times if the boot process produced an error. After a couple of attempts you should be able to turn the Wi-Fi radios on and the resulting indicator LED should be white (light blue) in color.
- Capellam44May 19, 2024AspirantI pushed the button several times over the course of an hour or so. With the WiFi light still red. I turned the router off for a few minutes then back on, still nothing. So I pushed the button once more just to make sure. Do I need to connect the computer again before it turns blue?
I used the nighthawk app went to settings and used smart connect but it never could find the router. The app, to me, is lacking some information and functions.
