jrman523
Aug 17, 2017Aspirant
Reday Nas Option missing
HELP!!!
I just got the R7900 Nighthawk and i wanted to use my extra 1TB extrenal hdd as a NAS device, i know this router is capable of it that is why i got it, but the issue is that i do not see th...
- Aug 23, 2017Yes the nas is connected via usb but I figured it out it was not registered so it was not working at all once I register readycloud account it all worked fine
Aug 17, 2017Guru - Experienced User
You don't have a ReadyNAS at all, so your problem is something else - either
- connecting your 1 TB drive to your router, or
- accessing your 1 TB remotely with ReadyCloud
Can you tell us which of those problems you have having?
- jrman523Aug 17, 2017AspirantSo the 1tb drive can be accessed it’s just I don’t get the option to set up readycloud from my router
- JamesGLAug 21, 2017NETGEAR Employee Retired
Hi jrman523,
Is the NAS connected to the router via USB port or LAN port?
- jadramadiAug 23, 2017AspirantYes the nas is connected via usb but I figured it out it was not registered so it was not working at all once I register readycloud account it all worked fine
