daytonal
Mar 24, 2020Tutor
Reduced internet bandwidth with R6400 Nighthawk and At&T BGW210-700
I decided to make the swith and go with fiber optic internet through AT&T. Intitially, I was running the 300mbs plan using at&t gateway (BGW210-700) and nighthawk R6400 router with no problems. Int...
- Mar 24, 2020
1. is your router running in router mode or AP (access point) mode? ATT devices are known to not function properly in passthrough/modem only mode. many have to leave their att device in router mode and put the netgear in AP mode.
2. did you or have you ran any traffic monitoring or qos? these features disable ctf (cut through fowarding) which is needed to hit gigabit speeds. I've read of devices having ctf left disabled even after disabling qos/traffic monitoring and a reboot. some have needed a full factory reset and manual re-install (not from backup). have you tried this?
3. What firmware is on the R6400?
Mar 24, 2020Guru - Experienced User
daytonal
Apr 01, 2020Tutor
thanks for the assistance. I changed the router mode to AP which resolved the LAN connection speed. The internet speed test was clocking around 850-900 mbs. Then I decided to do a factory reset on the router, left it in router mode and was still getting the LAN speed. So maybe it was setting within the router causing the lower speeds. The firmware is v1.0.1.52.
