Duckdive
Sep 18, 2015Aspirant
REDUCED WIFI SPEED with NETGEAR R7500
I am having troubles with my NETGEAR R7500. I upgraded to 110mps speed by am only getting speeds of around 54mps.
TheEther
Sep 18, 2015Guru
What kind of device are you using? Smartphone? Computer? If it's a computer, what is the model # of the Wi-Fi adapter?
- DuckdiveSep 20, 2015Aspirant
I have Wide Open West internet with 110mpbs
My lap top has Qualcomm Atheros AR956x wireless adapter. When i connect using cat5 cable i get extemely high speeds on test but i keep dropping off interent. As for the two computers, they have USB Realtek RTL8192CU 802.11N adapters.
Thank you for your assistance.
- TheEtherSep 20, 2015Guru
It's hard to find information about the Atheros AR956x, but it appears to be a single band (2.4 GHz only), single stream 802.11n Wi-Fi adapter. When using 20 MHz wide channels (very common with 2.4 GHz Wi-Fi when other Wi-Fi networks are present), the maximum link speed possible is 72.2 Mbps. Real world throughput will probably be in the 25 to 35 Mbps range. If no other Wi-Fi networks are present, then you may be able to use 40 MHz channels and a link speed of 150 Mbps. Real world throughput will be 50% of that or less (75 Mbps or less). But I wouldn't count on being able to use 40 MHz channels with 2.4 GHz Wi-Fi.
The Realtek RTL8192CU adapters are dual band (2.4 GHz and 5 GHz), dual stream 802.11n Wi-Fi adapters. These should be able to connect at a link speed of 300 Mbps at 5 GHz. Again, real world throughput will be 50% or less (150 Mbps or less).
With respect to the R7500, you will want to make sure that WMM is enabled. Without it, Wi-Fi will slow to a crawl. The other QoS functions, like upstream and downstream QoS, can remain off. Since you have pretty fast Internet service (120 Mbps), you probably won't benefit from QoS, so I recommend that you leave upstream and downstream QoS off, but feel free to experiment.
- DuckdiveSep 21, 2015Aspirant
Thank you very much for you imput! I enabled WMM and this has increased speed! Do you think going to a more powerful AC adapter on my computers (and laptop) would be beneficial? I am looking at the AC1200 from NETGEAR.
Also, on my laptop,when i plug cat5 cable into router, i get blazing speeds but my interenet keeps dropping off. Any suggestions?
Thank you kindly!
